Configuring User Parameters for User Data Repository
The UDR micro services have configuration options. The user should be able to configure them via deployment values.yaml.
Some of settings default value may change.Note:
- NAME: is the release name used in helm install command
- NAMESPACE: is the namespace used in helm install command
- K8S_DOMAIN: is the default kubernetes domain (svc.cluster.local)
Default Helm Release Name:- ocudr
Following table provides the parameters for global configurations
Table 6-1 Global configurations
| Service | Parameter | Description | Default Value | Range of Possible Values (if applicable) | Notes |
| - | mysql.dbServiceName | DB service to connect | udrdbservice | Not applicable | This is a read only parameter. you should not change the default value. |
| - | mysql.port | Port of MYSQL Database | 3306 | Not applicable | |
| - | mysql.dsusername | Mysql Username for UDR database set by MYSQL DBA | udruser | Not Applicable | |
| - | mysql.dspassword | Mysql password for UDR database set by MYSQL DBA | udrpasswd | Not Applicable | |
| - | mysql.dbname | Mysql Database name for UDR | udrdb | Not applicable | This is a read only parameter. you should not change the default value. |
| - | udrdbservice.primaryhost | Primary MYSQL Host IP or Hostname | ocudr-mysql | Not applicable |
UDR will connect to Primary MYSQL. If Primary MYSQL is not available, then it will connect to secondary host. Format:- NAME-mysql For MYSQL Cluster, use respective IP Address or Service. |
| - | udrdbservice.secondaryhost | Secondary MYSQL Host IP or Hostname | ocudr-mysql | Not applicable |
Format:- NAME-mysql For MYSQL Cluster, use respective Secondary IP Address or Service. |
udrdbservice.port |
udrdbservice.targetPort |
| - | jaeger.service.name | Jaegar Service Name installed in CNE | occne-tracer-jaeger-collector.occne-infra | Not applicable | |
| - | jaeger.service.port | Jaegar Service Port installed in CNE | 9411 | Not applicable | - |
| - | hikari.poolsize | Connection pool size | 25 | Not applicable | The hikari pool connection size is created at start up. |
| - | ambassador.id | Ambassador Identification | ambassador-ocudr | Not applicable | There can be multiple ambassador installed in same cluster for different NFs. So, this is unique identification for it. Format:- ambassador-NAME |
Table 6-2 table provides the parameters for nudr-drservice Micro service
Table 6-2 nudr-drservice Micro service
| - | deployment.replicaCount | Replicas of UDR pod | 2 | Not applicable | Number of UDR pods to be maintained by replica set created with deployment |
| - | image.pullPolicy | This setting will tell if image need to be pulled or not | Always | Possible Values are - Always
IfNotPresent Never |
| - | image.repository | Full Image Path | ocudr/nudr_datarepository_service | Not applicable | - |
| - | image.tag | Tag of Image | 1.3.0 | Not applicable | - |
| - | logging.level.root | Log Level | WARN |
Possible Values - WARN INFO DEBUG |
Log level of the UDR pod |
| - | maxReplicas | Maximum Replicas | 4 | Not applicable | Maximum number of pods |
| - | minReplicas | Minimum Replicas | 1 | Not applicable | Minimum number of pods |
| - | notify.port.http | HTTP port on which notify service is running | 5001 | Not applicable | |
| - | notify.port.https | HTTPS port on which notify service is running | 5002 | Not applicable | |
| - | resources.request.cpu | Cpu Allotment for UDR pod | 3 | Not applicable | The cpu to be allocated for UDR pod during deployment |
| - | resources.target.averageCpuUtil | CPU utilization limit for autoscaling | 80 | Not Applicable | CPU utilization limit for creating HPA |
| - | service.http2enabled | Enabled HTTP2 support flag for rest server | true | true/false | Enable/Disable HTTP2 support for rest server |
| - | service.port.http | HTTP port | 5001 | Not applicable | The http port to be used in UDR service |
| - | service.port.https | HTTPS port | 5002 | Not applicable | The https port to be used for UDR service |
| - | service.port.management | Management port | 9000 | Not applicable | The actuator management port to be used for UDR service |
| - | service.type | UDR service type | ClusterIP |
Possbile Values- ClusterIP NodePort LoadBalancer |
The kubernetes service type for exposing UDR deployment
Note: It is suggested to be set as ClusterIP (default value) always. |
| - | subscriber.autocreate | Flag to enable auto creation of subscriber | true | true/false | This flag will enable auto creation of subscriber when creating data for a non existent subscriber. |
| - | validate.smdata | Flag to enable correlation feature for smdata | true | true/false |
This flag will control the correlation feature for smdata. |
Following table provides information about the nudr-notify-service micro service.
Table 6-3 nudr-notify-service micro service
| Service | Parameter | Description | Default value | Range or Possible Values ( if applicable) | Notes |
| - | image.repository | Full Image Path | ocudr/nudr_notify_service | Not applicable | |
| - | image.tag | Tag of Image | 1.3.0 | Not applicable | |
Always IfNotPresent Never |
| - | notification.retrycount | Number of notifications to be attempted | 3 | Range: 1 - 10 |
Number of notification attempts to be done in case of notification failures The notification. retryerrorcodes configuration decides if the retry should be done. |
| - | notification.retryinterval | 5 |
Range: 1 - 60 Unit: Seconds |
The retry interval for notifications in case of failure. Unit is in seconds. The notification. retryerrorcodes configuration decides if the retry should be done. |
| - | notification.retryerrorcodes | Notification failures eligible for retry | "400,429,500,503" | Valid HTTP status codes comma separated | Comma separated error code should be given. These error codes will be eligible for retry notifications in case of failures. |
The cpu to be allocated for notify service pod during deployment. |
| - | resources.target.averageCpuUtil | CPU utilization limit for autoscaling | 80 | Not Applicable | CPU utilization limit for creating HPA. |
| - | service.http2enabled | Enabled HTTP2 support flag for rest server | true | true/false | This is a read only parameter. Do not change this value. |
| - | service.port.http | HTTP port | 5001 | Not applicable | The http port to be used in notify service to receive signals from nudr_drservice pod. |
| - | service.port.https | HTTPS port | 5002 | Not applicable | The https port to be used in notify service to receive signals from nudr_drservice pod. |
The actuator management port to be used for notify service. |
Note: It is suggested to be set as ClusterIP (default value) always |
Table 6-4 tables provides information about the nudr-nrf-client-service micro service.
Table 6-4 nudr-nrf-client-service micro service
| - | heartBeatTimer | Heart beat timer | 90 | Unit: Seconds | |
| - | image.repository | Full Image Path | ocudr/nrf_client_service | Not applicable | |
| - | image.pullPolicy | This setting will tell if image need to be pulled or not | Always | Possible Values -
| - | groupId | Group ID of UDR | udr-1 | Not applicable | |
| - | host.baseurl | NRF url for registration | http://ocnrf-endpoint.mynrf.svc.cluster.local/nnrf-nfm/v1/nf-instances | Not applicable | Url used for udr to connect and register with NRF |
| - | host.proxy | Proxy Setting | NULL | nrfClient.host | Proxy setting, if required, to connect to NRF |
| - | ssl | SSL flag | false | true/false | SSL flag to enable SSL with udr nrf client pod |
| - | logging.level.root | Log Level | WARN | Possible Values -
WARN INFO DEBUG |
Log level of the UDR nrf client pod |
| - | capacityMultiplier | Capacity of UDR | 500 | Not applicable | Capacity multiplier of UDR based on number of UDR pods running |
| - | supirange | Supi Range supported with UDR | [{\"start\": \"10000000000\", \"end\": \"20000000000\"}] | Valid start and end supi range | |
| - | priority | Priority | 10 | Priority to be sent in registration request | Priority to be sent in registration request |
| - | livenessProbeUrl | Liveness probe URL for nudr-drservice/ambassador | http://nudr-notify-service.myudr.svc.cluster.local:9000/actuator/health,http://nudr-drservice.myudr.svc.cluster.local:9000/actuator/health,http://ocudr-ambassador-admin.myudr.svc.cluster.local:8877/ambassador/v0/check_ready | Not Applicable | URL used by nrf-client-service to check liveness probe of nudr-drservice, nudr-notify-service, and ocudr-ambassador pods. Note: Be cautious in updating this value. You should consider namespace used for udr deployment and name resolution setting in k8s. |
| - | fqdn | UDR FQDN | ocudr-ambassador.myudr.svc.cluster.local | Not Applicable | FQDN to used for registering in NRF for other NFs to connect to UDR. Note: Be cautious in updating this value. You should consider namespace used for udr deployment and name resolution setting in k8s. |
Table 6-5 table provides information about the ocudr-ambassador Micro service
Table 6-5 ocudr-ambassador Micro service
| Service | Parameter | Description | Default Value | Range or Possible Values (if applicable) | Notes |
| - | adminService.annotations | Annotations with ambassador admin service | metallb.universe.tf/address-pool: signaling | Not applicable | This is a read only parameter. Do not change default value. |
| - | adminService.create | Enable Admin Service Creation | false | true/false | This is a read only parameter. Do not change default value. |
| - | adminService.type | Type of service of kubernetes service to be exposed | LoadBalancer |
| - | ambassador.id | Ambassador Identification | ambassador-ocudr | Not applicable | There can be multiple ambassadors installed in same cluster for different NFs. So, this is unique identification for it. |
| - | image.repository | Full Image Path | quay.io/datawire/ambassador | Not applicable | - |
| - | image.tag | Tag of Image | 0.50.3 | Not applicable | - |
| - | image.pullPolicy | This setting will tell if image need to be pulled or not | Always | Always/IfNotPresent/Never | - |
| -- | podAnnotations.prometheus.io/scrape | Prometheus related setting | true | true/false | - |
| -- | podAnnotations.prometheus.io/port | Prometheus related setting | 9102 | - | - |
| -- | prometheusExporter.enabled | Prometheus related setting | true | true/false | - |
| -- | resources.request.cpu | CPU Allotment for Ambassador pod | 3 | Not applicable | The cpu allocated for ambassador pod during deployment. |
| - | service.annotations | Annotations with ambassador service |
metallb.universe.tf/address-pool: signaling getambassador.io/config: | --- apiVersion: ambassador/v1 kind: Module name: ambassador ambassador_id: ambassador-ocudr config: service_port: 8080 |
Not applicable |
This is a read only parameter. Do not change default value. Service port can change based on site configurations |
| - | service.annotations.getambassador.io/config.ambassador_id | Ambassador Identification | ambassador-ocudr | Not applicable |
There can be multiple Ambassador installed in same cluster for different NFs. So, this is unique identification for it. Format:- ambassador-NAME |
| - | service.type | Type of service of kubernetes service to be exposed | LoadBalancer |
The kubernetes service type for exposing UDR deployment. Note: It is suggested to be set as LoadBalancer(default value) always. |
