UDM Deployment
This procedure describes the steps to deploy UDM on CNE. The below steps need to be executed from a server which has access to Kubectl and helm commands.
Table 2-4 UDM Deployment
| Step No.# | Procedure | Description |
| 1
Search helm chart | Execute the following command to check the version of the
helm chart installation. This step is required ocudm helm charts are part of
some helm repository.
helm search <chart_name> Note: chart_name can be obtained from Chart.yaml file in ocudm helm charts shared as part of the package. |
| 2
Prepare custom_values.yaml file | Prepare a custom_values.yaml file with the required parameter information. Refer to Configuration Parameter for more information on parameters. You can also download sample ocudm_values.yaml file from OHC. |
| 3
Deploy UDM using HELM repository | Execute the following command:
helm install <helm-repo>/chart_name -f <custom_values.yaml> --name <deployment_name> --namespace <namespace_name> --version <helm_version>Where: helm-repo: repository name where the helm images, charts are stored custom_values: helm configuration file which needs to be updated based on the deployment site requirement deployment_name and namespace_name: depends on customer configuration. For example: helm install ocudm-helm-repo/ocudm -f <custom values.yaml> --name ocudm --namespace udmsvc --version <helm version> |
| 4
Deploy UDM using extracted HELM charts | Execute the following command:
helm install -f <custom values.yaml> --name ocudm --namespace <namespace> <chartpath>./<chart>.tgz |
| 5
Check repo status | Execute
helm
status <deployment_name> to check the deployment status.
| 6
Check svc status | Check if all the services are deployed and running:
kubectl -n <namespace_name> get services |
| 7
Check pod status | Check if all the pods are up and running:
kubectl -n <namespace_name> get pods Check OCUDM Pod Details section given below for the pod details. |
kubectl get pods -n myudm NAME READY STATUS RESTARTS AGE ocudm-ausfueauthenticator-5745c4c594-4ttnz 1/1 Running 0 3d2h ocudm-endpoint-5f9b49689c-g4x2r 1/1 Running 0 3d2h ocudm-endpoint-5f9b49689c-gtw24 1/1 Running 0 3d2h ocudm-nudm-nrf-client-service-d65bf7b5b-s7dzx 1/1 Running 0 3d2h ocudm-nudm-sdm-notify-service-6459c7c8cf-hph7d 1/1 Running 0 3d2h ocudm-nudm-sdm-service-df485d6d-qtfgm 1/1 Running 0 3d2h ocudm-nudm-ue-auth-service-b66886d84-9p79t 1/1 Running 0 3d2h ocudm-nudm-uecm-service-c58c5d68c-7tbqz 1/1 Running 0 3d2h ocudm-perf-info-5f6b8f9856-kb5gj 1/1 Running 0 3d2h
