Pre-requisites
The prerequisites before installing Unified Data Repository
are:
- Access to OpenStack Environment: User should have access to an existing OpenStack Environment including the OpenStack Desktop. This environment is configured with appropriate resource flavors and network resources that allows its users to allocate resources to the virtual machines created via this procedure.
- Availability of a pub key: Users must have a pub key for logging into the Bootstrap Host. This key should be placed into the customer OpenStack Environment using Import Key tab on the Launch Instance→Key Pair dialog or via the Compute→Access and Security.
- OCUDR Software: User must
install Kubernetes v1.13.3 and HELM v2.12.3. UDR consists of:
- Helm Charts that reflect the OCUDR software version. It is a zipped tar file that you need to unzip.
- Docker images of the
micro-services that are shared as tar file. You need to untar it.
Additional softwares that you need to install as per the requirement of the services:
Software Version Notes elasticsearch 1.21.1 Needed for Logging Area elastic-curator 1.2.1 Needed for Logging Area elastic-exporter 1.1.2 Needed for Logging Area logs 2.0.7 Needed for Logging Area kibana 1.5.2 Needed for Logging Area grafana 2.2.0 Needed for Metrics Area prometheus 8.8.0 Needed for Metrics Area prometheus-node-exporter 1.3.0 Needed for Metrics Area metallb 0.8.4 Needed for External IP metrics-server 2.4.0 Needed for Metric Server tracer 0.8.3 Needed for Tracing Area Note:
If you want any of the above services and its respective software is not installed in CNE, then install that software before proceeding.Note:
Some of the above mentioned software(s) are updated frequently. Their later versions than those listed above should work with UDR 1.5. Some UDR features and services work differently depending on the software being used.
- Create Database User/Group:
Database administrator should create a user in MYSQL DB using MySQL NDB cluster
as UDR uses an NDB MySQL database to store the subscriber information. NDB
MySQL database provides HA and geo-redundancy capabilities.
The database administrator should also provide user with necessary permissions to access the tables in the NDB cluster. The steps to create a user and assign permissions are as follows:
- Login to the server where the ssh keys are stored and SQL nodes are accessible.
- Connect to the SQL nodes.
- Login to the Database as a root user.
- Create a user and assign
it to a group having necessary permission to access the tables on all the SQL
nodes:
CREATE USER '<username>'@'%' IDENTIFIED BY '<password>'; DROP DATABASE if exists <db_name>; CREATE DATABASE <db_name> CHARACTER SET utf8; GRANT SELECT, INSERT, CREATE, ALTER, DROP, LOCK TABLES, CREATE TEMPORARY TABLES, DELETE, UPDATE,EXECUTE ON <db_name>.* TO '<username>'@'%'; USE <db_name>;
- Network Access: The
Kubernetes cluster hosts must have network access to:
- Local docker image
repository where the Oracle Communications Unified Data Repository images are
available
To check if the Kubernetes cluster hosts has network access to the local docker image repository, try to pull any image with tag name to check connectivity by executing:
docker pull <docker-repo>/<image-name>:<image-tag> - Local helm repository
where the Oracle Communications Unified Data Repository helm charts are
available
To check if the Kubernetes cluster hosts has network access to the local helm repository, execute:
helm repo updateNote:
Some of the systems may need to use helm command withhelm --kubeconfig admin.confNote:
All the kubectl and helm commands (used in this document) must be executed on a system depending on the infrastructure of the deployment. It may be some client machine (virtual machine, server, local desktop and so on).
available
- Laptop/Desktop Client
Software: A laptop/desktop where the user executes deployment commands
should have:
helm repo update- Network access to the helm repository and docker image repository
- Configuration of Helm repository on the client
- Network access to the Kubernetes cluster
- Necessary environment
settings to run the
kubectlcommands. The environment should have privileges to create namespace in the Kubernetes cluster. - Helm client installed
with the
push plugin.
The environment should be configured so that the
'helm install'command deploys the software in the Kubernetes cluster.
