Installing Unified Data Repository
Following are the steps to install Unified Data Repository:
Table 2-1 Installation Procedure
S No. Installation Steps Description
1 Download the UDR package file from Oracle Software Delivery Cloud (OSDC).
Execute the following command to download UDR package.
<nfname>-pkg-<marketing-release-number>.tgz
For example:ocudr-pkg-1.5.0.0.0.tgz
2 Untar the UDR Package File.
Execute the following command to untar UDR Package File.
tar -xvf ocudr-pkg-1.5.0.0.0.tgz
This command results into ocudr-pkg-1.5.0.0.0 directory.
The directory consists of following:
  • UDR Docker Images File: ocudr-images-1.5.0.tar
  • Helm File: ocudr-1.5.0.tgz
  • Readme txt file. The Readme.txt contains cksum and md5sum of tarballs.
3
Verify the checksums of tarballs.
Execute the following command:
Readme.txt
4
Load the tarballs to docker images.
# docker load --input /root/ocudr-images-1.5.0.tar
5
Check if all the images are loaded
docker images
6
Tag the docker images to docker registry
docker tag <image-name>:<image-tag> <docker-repo>/<image-name>:<image-tag>
7
Push the docker images to docker registry
docker push <docker-repo>/<image-name>:<image-tag>
7
Untar Helm Files
tar -xvzf ocudr-1.5.0.tgz
8
Download the Unified Data Repository (UDR) Custom Template ZIP file
Download the UDR Custom Template ZIP file from OHC:
  • Go to the URL, docs.oracle.com
  • Navigate to
    Industries->Communications->Cloud Native Core
  • Click the
    link to download the zip file.
  • Unzip the template to get ocudr-custom-configTemplates-1.5.0.0.0 file that contains the following:
    • UDR_Dashboard.json: This file is used by grafana.
    • ocudr-custom-values-1.5.0.yaml: This file is used during installation.
    • rollback.py
    • upgrade.py
OCUDR Images and Helm Files
Following are the OCUDR Images.
Table 2-2 OCUDR Images
Container Image
Nudr-drservice nudr_datarepository_service
Nudr-notify -service nudr_notify_service
Nudr-nrf-client-service nudr-nrf_client_service
ocudr-endpoint ocingress_gateway
