Configuring User Parameters for Unified Data Repository
The UDR micro services have configuration options. The user should be able to configure them via deployment values.yaml.
The default value of some of the settings may change.
  • NAME: is the release name used in helm install command
  • NAMESPACE: is the namespace used in helm install command
  • K8S_DOMAIN: is the default kubernetes domain (svc.cluster.local)
Default Helm Release Name:- ocudr
Following table provides the parameters for global configurations.
Table 6-1 Global Configurations
Service Parameter Description Default Value Range of Possible Values (if applicable) Notes
- mysql.dbServiceName DB service to connect udrdbservice Not applicable This is a read only parameter. You should not change the default value.
- mysql.port Port of MYSQL Database 3306 Not applicable
- mysql.dsusername Mysql Username for UDR database set by MYSQL DBA udruser Not Applicable
- mysql.dspassword Mysql password for UDR database set by MYSQL DBA udrpasswd Not Applicable
- mysql.dbname Mysql Database name for UDR udrdb Not applicable This is a read only parameter. You should not change the default value.
- udrdbservice.primaryhost Primary MYSQL Host IP or Hostname ocudr-mysql Not applicable
UDR connects to Primary SQL node. If Primary SQL node is not available, then it connects to secondary SQL node.
Format:- NAME-mysql
For MYSQL Cluster, use respective IP Address or Service.
To connect to more SQL nodes, modify the nudr-drservice.yaml file available under charts/nudr-drservice/templates folder in UDR Helm chart.
In nudr-drservice.yaml, add more IP addresses under the subset section, in line no. 77 as given below.
subsets:
- addresses:
- ip: "{{ .Values.global.udrdbservice.primaryhost }}"
- ip: "{{ .Values.global.udrdbservice.secondaryhost }}"
- ip: "<sqlnode3_ip>"
- ip: "<sqlnode4_ip>"
- udrdbservice.secondaryhost Secondary MYSQL Host IP or Hostname ocudr-mysql Not applicable
Format:- NAME-mysql
To add secondary MYSQL Cluster, use respective Secondary IP Address or Service.
Refer to note given for udrdbservice.primaryhost
udrdbservice.port
udrdbservice.targetPort
- jaeger.service.name Jaegar Service Name installed in CNE occne-tracer-jaeger-collector.occne-infra Not applicable
- jaeger.service.port Jaegar Service Port installed in CNE 9411 Not applicable -
- hikari.poolsize Connection pool size 25 Not applicable The hikari pool connection size is created at start up.
- dbenc.passphrase Phrase for storing data into Database UDR UDM Db Encryption Passphrase Not applicable This should not be changed.
- dbenc.shavalue Encryption Key size 256 256 or 512
Table 6-2 table provides the parameters for nudr-drservice Micro service
Table 6-2 nudr-drservice Micro service
- deployment.replicaCount Replicas of UDR pod 2 Not applicable Number of UDR pods to be maintained by replica set created with deployment
- image.pullPolicy This setting tells if image needs to be pulled or not Always Possible Values are - Always
IfNotPresent
Never
- image.repository Full Image Path ocudr/nudr_datarepository_
service
Not applicable -
- image.tag Tag of Image 1.5.0 Not applicable -
- logging.level.root Log Level WARN
Possible Values -
WARN
INFO
DEBUG
Log level of the nudr-drservice pod
- maxReplicas Maximum Replicas 4 Not applicable Maximum number of pods
- minReplicas Minimum Replicas 1 Not applicable Minimum number of pods
- notify.port.http HTTP port on which notify service is running 5001 Not applicable
- notify.port.https HTTPS port on which notify service is running 5002 Not applicable
- resources.request.cpu Cpu Allotment for
nudr-drservice
pod
3 Not applicable The cpu to be allocated for nudr-drservice pod during deployment
- resources.requests.memory Memory allotment for nudr-drservice pod 4Gi Not applicable The memory to be allocated for nudr-drservice pod during deployment
- resources.limits.cpu Cpu allotment limitation 3 Not applicable
- resources.limits.memory Memory allotment limitation 4Gi Not applicable
- resources.target.averageCpuUtil CPU utilization limit for autoscaling 80 Not Applicable CPU utilization limit for creating HPA
- service.http2enabled Enabled HTTP2 support flag for REST server true true/false Enable/Disable HTTP2 support for REST server
- service.port.http HTTP port 5001 Not applicable The http port to be used in nudr-drservice service
- service.port.https HTTPS port 5002 Not applicable The https port to be used for nudr-drservice service
- service.port.management Management port 9000 Not applicable The actuator management port to be used for nudr-drservice service
- service.type UDR service type ClusterIP
Possbile Values-
ClusterIP
NodePort
LoadBalancer
The kubernetes service type for exposing UDR deployment
Note: It is suggested to be set as ClusterIP (default value) always.
- subscriber.autocreate Flag to enable auto creation of subscriber true true/false This flag enables auto creation of subscriber when creating data for a non-existent subscriber.
- validate.smdata Flag to enable correlation feature for smdata true true/false
This flag controls the correlation feature for smdata.
Following table provides information about the nudr-notify-service micro service.
Table 6-3 nudr-notify-service micro service
Service Parameter Description Default value Range or Possible Values ( if applicable) Notes
- deployment.replicaCount Replicas of UDR pod 2 Not applicable Number of notify service pods to be maintained by replica set created with deployment
- image.repository Full Image Path ocudr/nudr_notify_service Not applicable
Possible Values -
Always
If Not Present
Never
Possible Values -
WARN
INFO
DEBUG
Log level of the notify service pod
- notification.retrycount Number of notifications to be attempted 3 Range: 1 - 10
Number of notification attempts to be done in case of notification failures
On the basis of notification. retryerrorcodes configuration, retry is done.
- notification.retryinterval 5
Range: 1 - 60
Unit: Seconds
The retry interval for notifications in case of failure. Unit is in seconds.
- notification.retryerrorcodes Notification failures eligible for retry "400,429,500,503" Valid HTTP status codes comma separated Comma separated error code should be given. These error codes are eligible for retry notifications in case of failures.
- resources.requests.cpu Cpu Allotment for nudr-notify-service pod 3 Not applicable
The cpu to be allocated for notify service pod during deployment.
Memory allotment for nudr-notify-service pod
4Gi Not applicable The memory to be allocated for nudr-notify-service pod during deployment
- resources.target.averageCpuUtil CPU utilization limit for autoscaling 80 Not Applicable CPU utilization limit for creating HPA.
- service.http2enabled Enabled HTTP2 support flag true true/false This is a read only parameter. Do not change this value.
- service.port.http HTTP port 5001 Not applicable The http port to be used in notify service to receive signals from nudr_notify-service pod.
- service.port.https HTTPS port 5002 Not applicable The https port to be used in notify service to receive signals from nudr_notify_service pod.
The actuator management port to be used for notify service.
Possbile Values-
ClusterIP
NodePort
LoadBalancer
Table 6-4 tables provides information about the nudr-nrf-client-service micro service.
Table 6-4 nudr-nrf-client-service micro service
- heartBeatTimer Heart beat timer 90 Unit: Seconds
- image.repository Full Image Path ocudr/nrf_client_service Not applicable
- image.pullPolicy This setting will tell if image need to be pulled or not Always Possible Values -
Always
If Not Present
Never
- groupId Group ID of UDR udr-1 Not applicable
- host.baseurl NRF url for registration HTTP://OCNRF-ENDPOINT.MYNRF.SVC.CLUSTER.LOCAL/NNRF-NFM/V1/NF-INSTANCES Not applicable Url used for udr to connect and register with NRF
- host.proxy Proxy Setting NULL nrfClient.host Proxy setting, if required, to connect to NRF
- ssl SSL flag false true/false SSL flag to enable SSL with udr nrf client pod
- logging.level.root Log Level WARN Possible Values -
WARN
INFO
DEBUG
Log level of the UDR nrf client pod
- capacityMultiplier Capacity of UDR 500 Not applicable Capacity multiplier of UDR based on number of UDR pods running
- supirange Supi Range supported with UDR [{\"start\": \"10000000000\", \"end\": \"20000000000\"}] Valid start and end supi range
- priority Priority 10 Priority to be sent in registration request Priority to be sent in registration request
- livenessProbeUrl Liveness probe URL for nudr-drservice/api-gateway HTTP://NUDR-NOTIFY-SERVICE.MYUDR.SVC.CLUSTER.LOCAL:9000/ACTUATOR/HEALTH,HTTP://NUDR-DRSERVICE.MYUDR.SVC.CLUSTER.LOCAL:9000/ACTUATOR/HEALTH,HTTP://OCUDR-ENDPOINT.MYUDR.SVC.CLUSTER.LOCAL:9000/ACTUATOR/HEALTH?%3E Not Applicable
URL used by nrf-client-service to check liveness probe of nudr-drservice, nudr-notify-service and ocudr-ambassador pods.
Note: Be cautious in updating this value. Should consider helm release name, namespace used for udr deployment and name resolution setting in k8s.
- fqdn UDR FQDN ocudr-endpoint.myudr.svc.cluster.local Not Applicable
FQDN to used for registering in NRF for other NFs to connect to UDR.
This table provides information about the ocudr-endpoint Micro service
Table 6-5 ocudr-endpoint Micro service
Service Parameter Description Default Value Range or Possible Values (if applicable) Notes
- fullnameOverride Name to be used for deployment endpoint Not applicable
- jaegerTracingEnabled Enable/Disable Jaeger tracing false true/false
- opentracing.jaeger.udpsender.host Jaeger host jaeger-agent.cne-infra Not applicable
- opentracing.jaeger.udpsender.port Port to connect to jaeger service 6831 Valid Port
- image.name Docker image name ocingress_gateway Not applicable
- image.registry Docker registry to pull image reg-1:5000/ocudr Not applicable
- image.tag Image version tag 1.5.0 Not applicable
Possible Values -
Always
IfNotPresent
Never
- deployment.replicaCount Number of ocudr-endpoint pods to be maintained by replica set created with deployment 1 Not applicable
- service.type ocudr-endpoint service type LoadBalancer
Possible Values-
ClusterIP
NodePort
LoadBalancer
- service.metalLbIpAllocationEnabled Enable or disable Address Pool for Metallb true true/false
- service.name Service name to be used ocudr-endpoint Not applicable
- service.metalLbIpAllocationAnnotation Address Pool for Metallb "metallb.universe.tf/address-pool: signaling" Not applicable
- service.port.http Port on which service is exposed 80 Valid Port
- service.targetPort.http Actual port on which your application is running inside the container 8081 Valid port
- ports.containerPort ContainerPort represents a network port in a single container 8081 Valid port
- service.staticNodePortEnabled If Static node port needs to be set, then set staticNodePortEnabled flag to true and provide value for staticNodePort false Not applicable
- resources.requests.cpu Cpu allotment for ocudr-endpoint pod 3 Not Applicable
- resources.requests.memory Memory allotment for ocudr-endpoint pod 4Gi Not applicable
- minAvailable Number of pods always running 1 Not Applicable
- log.level Logs to be shown on ocudr-endpoint pod WARN valid level
- initssl To Initialize SSL related infrastructure in init/update container false Not applicable
- oauthValidatorEnabled OAUTH Configuration false Not applicable
- enableincominghttp Enabling for accepting http requests true Not applicable
- maxConnectionsQueuedPerDestination Queue Size at the ocudr-endpoint pod 5000 Not applicable
- maxConnectionsPerIp Connections from endpoint to other microServices 10 Not applicable
- routesConfig Routes configured to connect to different micro services of UDR
-id:traffic_mapping_http
uri:http://{{ .Release.Name }}-nudr-drservice:5001
path:/nudr-dr/**
-id:traffic_mapping_http_prov
path:/nudr-dr-prov/**
-id:traffic_mapping_http_mgmt
path:/nudr-dr-mgm/**
-id:traffic_mapping_http_udsf
path:/nudsf-dr/**
-id:traffic_mapping_http_group
path:/nudr-group-id-map/**
-id:traffic_mapping_http_group_prov
path:/nudr-group-id-map-prov/**
Not applicable
