Resource Principal Policies
If using resource principal, for example with Spark streaming, you need specific policies in Data Flow.
You can add these policies for resource principal in three ways:
Use Policy Builder Data Flow Resource Principal Templates
Use the Data Flow templates in the policy builder to set your policies for resource principals.
- Let Data Flow resource use Object Storage
- Allow a dynamic-group to create and use objects in a specified Object Storage location. Create the policy in the tenancy.
- Let Data Flow resource consume from Oracle Streaming
- Allow a dynamic-group to consume from Oracle Streaming. Create the policy in the tenancy.
- Let Data Flow resource write to Oracle Streaming
- Allow a dynamic-group to produce to Oracle Streaming. Create the policy in the tenancy.
Use a Dynamic Group
Dynamic groups allow you to write more concise policies and reuse the same group. You can also refer to tags and limit a group to a particular Data Flow application.
- Specify the compartment to allow all Data Flow runs
from:(Optional) You can limit to a specific Data Flow application within a compartment:
ALL {resource.type='dataflowrun', resource.compartment.id='<compartment_id>'}ALL {resource.type='dataflowrun', resource.compartment.id='<compartment_id>', tag.oci-dataflow.application-id.value='<application_id>'} - Allow the Data Flow resource principal to consume from a Streaming stream pool and an Object Storage bucket:
ALLOW DYNAMIC-GROUP DF-IN-ROOT TO {STREAM_INSPECT, STREAM_READ, STREAM_CONSUME} IN TENANCY WHERE ANY {target.streampool.id = '<streampool_id>'} ALLOW DYNAMIC-GROUP DF-IN-ROOT TO MANAGE OBJECTS IN TENANCY WHERE ANY {target.bucket.name = '<bucket_name>', target.bucket.name = '<bucket_name>'}
Use All-in-one Policy
All Data Flow runs from a specific compartment consume from a specific stream pool and an Object Storage bucket.
ALLOW ANY-USER TO {STREAM_INSPECT, STREAM_READ, STREAM_CONSUME} IN TENANCY WHERE ALL
{request.principal.type='dataflowrun', request.resource.compartment.id = '<compartment_id>', target.streampool.id = '<streampool_id>'}
ALLOW ANY-USER TO MANAGE OBJECTS IN TENANCY WHERE ALL
{request.principal.type='dataflowrun', request.resource.compartment.id = '<compartment_id>', target.bucket.name = '<bucket_name>'}
