Use ODBC to Connect Tableau to a Data Flow SQL Endpoint
Download, install, and configure ODBC on MAC OS or Windows to connect Tableau to a Data Flow SQL Endpoint.
Downloading and Installing the ODBC Driver on Mac OS
Follow these steps to download and install an ODBC driver to use with Tableau on Mac OS.
Download the ODBC driver.
- In the global search bar, search for
Data Flowand select Data Flow Service. - Select SQL Endpoints in the leftmost side navigation.
- Select any SQL Endpoint from the list. The details page for that SQL Endpoint is displayed.
- Under Connect, select Drivers.
- Under ODBC, select Download ODBC driver.
- Select Mac. The download begins.
- When the download completes, extract the downloaded zip file.
Double-click to install the driver.
The installation window opens.
Select Continue.
Read the license agreement that's displayed.
- Select Agree.
- (Optional) To change the installation directory from the default, select Change install location, browse to where you want to install, and select OK.
- Select Next to confirm the installation directory.
- Select Install.
When the installation completes, select Finish.
The driver installation directory is:
/Library/simba/ocispark/lib/universal/libsparkodbc_sbu.dylib - (Optional)
Install the ODBC Manager.
The ODBC Manager is a tool for configuring drivers and creating and managing DSNs. The tool is optional because you can also create DSNs manually by editing the appropriate
odbc.inifile.- Download the ODBC Manager from the download site.
- Double-click the downloaded
.dmgfile. - Double-click
ODBC Manager.pkgfile. - Follow the prompts to install it.
Configuring the ODBC Driver on Mac OS
Follow these steps to configure the ODBC Driver on Mac OS.
You can create User DSNs (only accessible by the user who created it on the workstation) or System DSNs (accessible by any user signed in to the workstation).
Get the host name for the SQL Endpoint to connnect to.
- Open the Details Page for the SQL Endpoint when it's active.
- Select Drivers.
- Under ODBC driver, select Show Details. A pop-up appears.
- Select Show on the Host name string. The full Host name is displayed.
- Select Copy on the Host name string. The full Host name is copied to the clipboard.
- Save the Host name for later use.
- (Optional)
Create a DSN using the ODBC Manager.
Start ODBC Manager.
Select User DSN or System DSN as appropriate.
Select Add.
Select
Simba OCI Spark ODBC Driver. -
Select OK.
Enter the name of the DSN, for example,
Data Flow SQL Endpointand, optionally, add a description. -
Create a Keyword Value pair for each DSN parameter.
Select Add to create a Keyword Value pair.
Select Keyword and replace it with the parameter name.
Select Value and replace it with the value for the parameter.
- Repeat steps g to j for each parameter.
- Add the connection authentication details:
- For connecting to a SQL Endpoint using an API signing key not at
the default location
~/.oci/config, add the parameter:
whereOCIConfigFile=ConfigFileLocationConfigFileLocationis the absolute path to the OCI configuration file to use with the connection.Optionally, set the OCIProfile field to the name of the OCI profile in the configuration file to use with the connection:
If no profile is specified, the connector try to use the profile named DEFAULT:OCIProfile=<profile_to_use>OCIProfile=<profile_to_use> - For connecting to a SQL Endpoint using a token (through the
browser), omit the
OCIConfigFileparameter from the DSN configuration.
Select OK to create the DSN.
Note
If you create the first user or system DSN for the ODBC driver, the ODBC Manager creates theodbc.inifile in the corresponding directory for the type of DSN created. If you create more DSNs, the ODBC Manager adds entries for each DSN to the existingodbc.inifile. Theodbc.inifile is under the directory~/Library/ODBCfor User DSNs and/Library/ODBCfor System DSNs. -
- (Optional)
Create a DSN by adding an entry to
odbc.ini.If a User DSN or a system DSN has already been created for the driver, add the new entry to the existingodbc.inifile. If creating the first DSN for the driver, manually create theodbc.inifile and add the entry to the file.- If creating the first DSN in the empty
odbc.inifile, create a section for ODBC Data Sources (for the first time only), by adding the following line to theodbc.inifile:[ODBC Data Sources] -
For each DSN, specify the following:
- Under
[ODBC Data Sources]specify the DSN name and ODBC driver name (which is Simba OCI Spark ODBC Driver), in the form,<dsn_name> = <driver_name>. For example:[ODBC Data Sources]dsn_name = Simba OCI Spark ODBC Driver - Create a section for DSN configuration, by adding
[dsn_name]in a new line at the end of the file.[dsn_name] - Under the created DSN Section specify the directory path of the
driver file, in the
form:
Driver = /Library/simba/ocispark/lib/universal/libsparkodbc_sbu.dylib -
Provide the connection parameters such as host, and config file. Those connection parameters you add to the DSN don't need to be specified in the ODBC connect string.
- For connecting to SQL Endpoint using an API signing
key (not at the default location of
~/.oci/config), add the parameter:
whereOCIConfigFile=ConfigFileLocationConfigFileLocationis the absolute path to the OCI configuration file to use for the connection.Optionally, set the
OCIProfilefield to the name of the OCI profile in the config file to use for the connection. If no profile is specified, the connector tries to use the profile named,DEFAULT:OCIProfile=PROFILE_TO_USE - To connect to a SQL Endpoint using a token
(browser-based), you can omit the
- Any other parameters are specified in the form of
<parameter_name> = <value>.The following example shows anodbc.inifile that configures the data sources using the API key:[ODBC Data Sources] Data Flow SQL Endpoint = Simba OCI Spark ODBC Driver [Data Flow SQL Endpoint] Driver = /Library/simba/ocispark/lib/universal/libsparkodbc_sbu.dylib Description = Description of the connection Host = amaaaaaaezym32iajmhpmxybehc7plnvpxsmjhleiav37x5rm7pjx476ewqa.interactive.dataflowclusters.us-ashburn-1.oci.oc-test.com OCIConfigFile = /Users/username/.oci/config OCIProfile = OCIProfileToUse OCIIgnoreDriverNoPrompt = 1
- Under
- Confirm that path of the OCI configuration file to use the API signing key for authentication is correct.
- Validate the private key file path in the configuration.
Downloading and Installing the ODBC Driver on Windows
Follow these steps to download and install an ODBC driver to use with Tableau on Windows/
Download the Windows ODBC driver from .
- Select Windows. The download begins.
Extract the
.zipfile. -
Double-click the 32-bit installer,
Simba OCI Spark 2.6 32-bit.msi, if the system is 32-bit, or double-click the 64-bit installer ,Simba OCI Spark 2.6 64-bit.msi, if the system is 64-bit. - Select Next.
- Accept the terms of the License Agreement.
- Select Next.
- (Optional)
To change the install directory from the default:
- Select Change....
- Browse to the required directory.
- Select OK.
- To accept the install directory, select Next.
- Select Install.
- When the installation completes, select Finish.
Configuring the ODBC Driver on Windows
Follow these steps to configure the ODBC Driver on Windows.
- Select Drivers.
Create a DSN.
Open the ODBC Data Sources App.
Select Add.
Select
Select Finish.
For authentication, you can use an API signing key to connect to a SQL Endpoint, or you can use a token (browser-based) to connect to a SQL Endpoint.
- To use an API signing key
- Set OCI Config File to the absolute path to the OCI configuration file to use for the connection.
- Optionally, set the OCI
profile to use for the connection. If no profile
profile named
DEFAULT. - Check Ignore SQL_DRIVER_NOPROMPT.
- Select OK to save the settings.
- To use a token (browser-based)
- You can opt not to set up DFI Options entirely and only
test the DSN (step iv), or select DFI
Options and continue with the following steps:
- Set the OCI Config File field to a path that doesn't contain an OCI configuration file to use token-based authentication.
- To display a web browser used to complete the
token-based authentication flow even when
SQL_DRIVER_NOPROMPTis enabled, check Ignore SQL_ DRIVER_NOPROMPT. - Select OK to save the settings.
- To test the DSN, select Test.
Connecting Tableau to a Data Flow SQL Endpoint Using ODBC
Follow these steps to connect Tableau to a Data Flow SQL Endpoint Using ODBC.
- Open Tableau.
Select Other Databases (ODBC).
A new window opens.
- Check DSN.
Select the DSN,
Data Flow SQL Endpoint, from the list.All the required connection parameters are automatically populated. - Select Sign In.
