Viewing the Details of a Project
Access resources such as data flows and tasks that are contained in a project in a Data Integration workspace.
    1. On the Projects list page, select the name of a project. If you need help finding the list page or the project, see Listing Projects.
      The project details page opens, in which you can find resources such as first-level folders, tasks, data flows, and pipelines that are created in that project.
    2. Under Details, use the links to access the resources that you can work with in the project.
      For example, select Pipelines to list the pipelines that are created in the project.
    If you created a project with sample artifacts, the samples are available in the v1_0 folder.
    For details about project copy requests, see Monitoring Project Copy Requests and Viewing the Details of a Project Copy Request.
  • Use the oci data-integration project get command and required parameters to retrieve a project:
    oci data-integration project get [OPTIONS]
    For a complete list of flags and variable options for CLI commands, see the Command Line Reference.
  • Run the GetProject operation to retrieve a project.
