Label Studio
Troubleshoot issues when using Label Studio.
Documents aren't visible in Label Studio
Incorrect configuration of these settings might prevent documents from appearing
- Ensure that the OCI Text Extraction Service is up and running, and you can connect to it successfully.
- Verify that the OCR service port matches the port configured in the Connect Model settings in Label Studio.
- Confirm that you have correctly configured the labeling set up for the Custom KV task. You must use the exact labeling configuration provided in the documentation.
