Creating a Product
Create a custom product in Fleet Application Management. When you create a product, it's automatically assigned an active status.
Review the following requirements before creating a custom product:
- You must own all necessary rights for a third-party product or service that you choose to use in OCI.
- You must review the product license agreement terms before using the product in OCI.
Note
When you create a product, a compliance policy for the product is generated automatically.
Use the oci fleet-apps-management fleet-apps-management-admin platform-configuration create-platform-configuration-product-config-category-details command and required parameters to create a custom product:
oci fleet-apps-management fleet-apps-management-admin platform-configuration create-platform-configuration-product-config-category-details --compartment-id <compartment_OCID> --config-category-details-products <json_file_or_string> --display-name <text> [OPTIONS]For a complete list of flags and variable options for Fleet Application Management CLI commands, see the CLI for Fleet Application Management.
Run the CreatePlatformConfiguration operation to create a custom product.
