Listing Products
List custom products and Oracle-defined products in Fleet Application Management along with their versions and status.
Note
The Oracle Exadata Database Service, Oracle Exadata OS, and Oracle Clusterware versions depend on the versions supported by these services. For versions, see Supported Products.
    1. Open the navigation menu  and select Observability & Management. Under Fleet Application Management, select Administration.
    2. Under Metadata management (on the left side of the page), select Products.
      The Products list page opens. By default, all custom products in the selected compartment are displayed in a table.
    3. To view the products in a different compartment, use the Compartment filter to switch compartments.
      You must have permission to work in a compartment to see the resources in it. If you're not sure which compartment to use, contact an administrator. For more information, see Understanding Compartments.
    4. To view the Oracle-defined products, use the Publisher filter to select Oracle defined.
      Tip
      To view general information about a product, expand the product name.
    Filtering List Results
    Use filters to limit the products in the list. Perform one of the following actions depending on the options that you see:
    • From the Search and Filter box above the list table, select one or more filters and specify the values that you want to use to narrow the list. In general, the filters correspond to the columns shown in the list table, although some filters represent attributes that aren't shown in the table. The Compartment filter is always displayed next to Applied filters.
    • On the left side of the list page, select a value from one of the available filters, such as compartment, state, or tags.
    Change the order of the items in the list table by using the sort icons next to the column names.
    For information about searching for resources and managing the columns in the list table, if those features are available, see Listing Resources.
  • Use the oci fleet-apps-management fleet-apps-management-admin platform-configuration-collection list-platform-configurations command and required parameters to list products:
    oci fleet-apps-management fleet-apps-management-admin platform-configuration-collection list-platform-configurations [OPTIONS]
    For a complete list of flags and variable options for Fleet Application Management CLI commands, see the CLI for Fleet Application Management.
  • Run the ListPlatformConfigurations operation to list products.
