Moving a Product to a Different Compartment
Move a product in Fleet Application Management to another compartment.
Note
When moving a product to another compartment, note that the product is no longer accessible from this compartment.
- On the Products list page, find the product that you want to work with. If you need help finding the list page or the product, see Listing Products.
- From the Actions menu for the product, select Move resource.
- In the Move resource panel, select the destination compartment from the list.
- Select Move resource.
Use the oci fleet-apps-management fleet-apps-management-admin platform-configuration change-compartment command and required parameters to move a custom product to a different compartment:
oci fleet-apps-management fleet-apps-management-admin platform-configuration change-compartment --compartment-id <compartment_OCID> --platform-configuration-id <platform_configuration_OCID> [OPTIONS]For a complete list of flags and variable options for Fleet Application Management CLI commands, see the CLI for Fleet Application Management.
Run the ChangePlatformConfigurationCompartment operation to move a custom product to another compartment.
