Known Issues for Roving Edge
The following known issues are identified in Roving Edge.
- Public SDK and public Terraform not available for data sync at this time
- edgepeerconnection can remain ACTIVE when peerserialnumber is incorrect
- Load Balancer session persistence not available for this release
- VCN-related network resources become stuck
- OKE cluster add-ons not supported at this time
- Yum package installs might fail when using OL7.9 image
- During a reboot or power cycle, the device status might report "Unexpected Error!"
- An Oracle Linux 9 instance takes a while to boot
At this time, public SDK and public Terraform versions are not available for data sync.
- Details
- While public SDK and Terraform are not currently supported, there are supported versions of available.
- Workaround
- Use the following supported SDK and Terraform versions for data sync operations:
If you enter an incorrect peerSerialNumber while creating an EdgePeerConnection, the create job can remain in the ACTIVE state indefinitely and requires manual cancellation to recover.
- Details
- When
EdgePeerConnectionis created with incorrect peer connection parameters—most commonly an invalidpeerSerialNumber—the workflow can stall while waiting for the tunnel to come up, leaving the associated work item in an Active state indefinitely with progress such as “checking if tunnel is connected.” Depending on where the failure surfaces, one rack may fail later during trust exchange with an explicit serial-number-related error, while the other may never time out and remains stuck in Creating/Active. - Workaround
- Manually cancel the Active work item. After cancellation, delete the incomplete
EdgePeerConnectionand recreate it using the correct peer parameters.Gather the ID of the stalled job using the
getallactiveJobscommand.Gather the Active work item within that job, using the
show job id=<jobId>command.View the details of the work item using the
showworkItem id=<workItemId>command.Cancel the active work item using the
cancelworkItem id=<workItemId>command.Delete the
EdgePeerConnectionusing thedelete EdgePeerConnection id=<Id>Recreate the
EdgePeerConnectionusing the correctpeerSerialNumber.
At this time, Load Balancer session persistence is not supported for this release.
- Details
- Session persistence options, such as cookie-based or source IP-based persistence, are currently unavailable in the Load Balancer for this release.
- Workaround
- We're working on a fix for this issue.
VCN network resources might get stuck in PROVISIONING or FAIL states, because of OVN access object pool exhaustion.
- Details
- You may encounter a “Northbound database access connection object” error when the OVN (Open Virtual Network) access object pool is exhausted. When this happens, API calls can repeatedly fail and VCN network resources may get stuck in PROVISIONING or FAIL states.
- Workaround
- Increase the pool size OVN Northbound database access connections from 32 to 64.
At this time, enabling OKE add-ons might fail across multiple cluster configurations.
- Details
- Customers might see add-on enablement operations fail regardless of cluster type or node shape. This behavior has been observed on Flannel clusters with non-GPU worker node shapes and may impact other configurations as well.
- Workaround
- We're working on a solution.
At this time, yum operations might fail on PCA environments when using the uln-pca-Oracle-Linux-7.9-2025.07.21_0.oci image because of Oracle Linux 7 Extended Lifecycle Support (ELS) repositories being enabled by default.
- Details
- In the latest OL7.9 image, ELS repositories (for example, ol7_UEKR6_ELS) are enabled by default. These repos might resolve to
yum.oracle.com, where the ELS content is not published, resulting in404 Not Founderrors for repository metadata (for example,repodata/repomd.xml) and causingyumto fail. - Workaround
- Disable ELS repositories when running
yum.
- Details
As of version 2.18, the following error might be displayed when you reboot or power cycle a device:
Version : *** Unknown ***System Time UTC : 2025-08-28 18:14:31 Boot Time : 2025-08-28 17:39:18 Device Serial Id : Unexpected Error! Unlock Status : Unexpected Error! Auto Unlock Status : Unexpected Error! Diag Mode : *** Unknown *** Red API Services Status : *** Unknown *** Red HW Services Status : *** Unknown *** Press ENTER to return... - Workaround
Reboot the device until the error is no longer displayed. See Rebooting a Roving Edge Device.
An Oracle Linux 9 instance might take longer than 4 minutes to boot.
- Workaround
In the instance, run the following command to check if the bootloader entry contains a
netrootsetting that's set to an iscsi target:grep "netroot=iscsi" /boot/loader/entries/*$(uname -r).conf -
If the command returns any result, remove the
netrootoption from the bootloader entries using this command:sed -i 's/netroot=iscsi:[^ ]\+ / /' /boot/loader/entries/*.conf
