Entering Variable Values for a Cross Dimension Variable
A cross dimension variable is a Oracle Hyperion Planning, Oracle General Ledger, or Oracle Essbase replacement variable. It contains a member from multiple dimensions that enables you to launch business rules across dimensions.
To enter values for a cross dimension variable:
- Select RIP if the variable has a runtime prompt.
Planning and Essbase users only
If you do not select RTP, you must enter a value for the variable.
A function can be used, but the function must return a single member from the dimension to be a valid selection.
