Removing a System Template from a Business Rule
You can remove system templates from business rules.
To remove a system template:
- In System View, right-click the business rule from which you want to remove the system template, and then select Open.
- For a graphical rule, in the flow chart of the Rule Designer, right-click the system template, and then select Remove.
- For a script rule, highlight the entire line that contains the system template, then right-click, and then select Delete.
- Click
