7 Smart View Panel Navigation
Displays the keys for navigating in the Oracle Smart View for Office panel.
Table 7-1 displays the keys for navigating in the Smart View Panel.
Table 7-1 Smart View Panel Navigation
Keys | Action |
Alt+S+P | Launch the Smart View Panel |
F6 | Move between the Smart View Panel and Office components such as the active application window or ribbon |
Tab | Move through Smart View Panel from top to bottom |
Shift+Tab | Move through Smart View Panel from bottom to top |
Up and down arrow keys | Scroll through items in tree view
Activate the drop-down menu on the Home button and Go button |
Left and right arrow keys |
In toolbars, move through buttons In tree views, expand or collapse a node |
Alt+down arrow | Open the drop-down menu |
Up and down arrow keys | Scroll through drop-down list |
Enter | Select an item in the drop-down menu |
Escape | Cancel selection |
