4 Installing and Configuring Help Locally
After installing Oracle Smart View for Office, the online help is retrieved from a URL hosted on the Oracle.com web site. This is the default behavior for Smart View, and no changes are required by users to launch help.
However, you may require that the help be installed locally for Section 508 accessibility purposes. To accommodate this, help must be downloaded from My Oracle Support and placed on a local drive, and the Smart View properties.xml
file must be modified..
To install and configure Smart View help locally:
Obtain the help zip file for this release from My Oracle Support.
Extract the contents of the patch zip file to a local folder on the computer where Smart View is installed.
For example, extract the contents locally to:
C:\Oracle\SmartView\
Under the
smartview_help
folder, there are 28 language folders; for example:C:\Oracle\SmartView \smartview_help \ar \cs \da \de \el \en \es \fi \fr \fr_CA \he \hu \it \ja \ko \nl \no \pl \pt \pt_BR \ro \ru \sk \sv \th \tr \zh_CN \zh_TW
The following language folders contain translated versions of the Smart View help:
\de \es \fr \it \ja \ko \nl \pt_BR \zh_CN \zh_TW
The remaining language folders contain the English version of the help. When you run Smart View in one of those languages (for example, Swedish) and you click a button for Help, the English help is displayed.
Additionally, the English folder contains a copy of the help in PDF format,
smartview_user.pdf
Modify the
helpurlcontext
property in the Smart Viewproperties.xml
file:-
In your Smart View installation, navigate to the
SmartView\cfg
folder. -
Make a backup copy of the original
properties.xml
file. -
Open
properties.xml
for editing. -
Modify the
helpurlcontext
property, providing the path to the folder that is parent to the language folders, providing the path to the folder that is parent to the language folders using the following syntax:<helpurlcontext>file:///parent_language_folder_path/</helpurlcontext>
Tip:
Use forward slashes in the syntax and ensure that you enter a final forward slash (/) after the parent language folder path that you provide.
Using the example from step 2, after extracting the zip contents to
C:\Oracle\SmartView
, thesmartview_help
folder is the parent folder of the language folders. Thus, you would modify the parent_language_folder_path placeholder as follows:<helpurlcontext>file:///C:/Oracle/SmartView/smartview_help/</helpurlcontext>
Restart your Microsoft Office applications and access the help from the Smart View ribbon.
Repeat this procedure for each computer that requires Smart View local help.
