Smart View Panel
Displays the access keys for navigating in the Smart View panel.
See Considerations for information on access keys for the Document Contents pane.
Keys | Action |
Alt+S+P | Launch the Smart View Panel |
F6 | Cycle through the active Office ribbon tab; the active Office application area, such as a sheet, document, or slide; the task pane that displays the Smart View Panel; and the Office status bar |
Tab | Move through Smart View Panel from top to bottom |
Shift+Tab | Move through Smart View Panel from bottom to top |
Up and down arrow keys | Scroll through items in tree view
Activate the drop-down menu on the Home button and Go button |
Left and right arrow keys |
In toolbars, move through buttons In tree views, expand or collapse a node |
Alt+down arrow | Open the drop-down menu |
Up and down arrow keys | Scroll through drop-down list |
Enter | Select an item in the drop-down menu |
Escape | Cancel selection |
Considerations
Document Contents Pane
After launching an ad hoc grid or form, the Document Contents pane is displayed in the lower portion of the Smart View Panel. In the Document Contents pane, you use the keys noted above to navigate most user interface elements in the pane. You use the Tab key, arrow keys, and the space bar, to navigate to and select buttons that minimize and maximize the entire pane as follows:
- To minimize the Document Contents pane:
Press Tab to navigate to the Minimize button,
, and then press the Space bar to activate the button and minimize the pane.
- To maximize the Document Contents pane:
, then use the right arrow key to move to the Maximize button,
, and then press the Space bar to activate the button and maximize the pane.
- To restore the Document Contents pane when the pane has been
maximized:
Press Tab to navigate to the Switch to button,
, then use the right arrow key to move to the Minimize button,
, and then press the Space bar to activate the button.
If the previous state of the pane was minimized, then the pane is again minimized.
If the previous state of the pane was the initial split view (Smart View Panel on top, Document Contents pane at the bottom), then the pane is restored to the split view.
- To restore the initial split view of the Smart View Panel and Document
Contents pane when Document Contents is minimized:
Press Tab to navigate to the Split button,
, and then press the Space bar to split and restore the initial panel view with the Smart View Panel at the top and the Document Contents pane at the bottom.
Smart View Panel
Use the Tab key, arrow key, and space bar to minimize and expand the entire Smart View Panel, including the Document Contents pane:
- To minimize the Smart View Panel:
, then press the right arrow key to move to the Minimize the Smart View Panel button,
, and then press the Space bar to activate the button and minimize, or collapse, the Smart View Panel.
- To maximize the Smart View Panel:
, then press the right arrow key to move to the Maximize the Smart View Panel button,
