Oracle BI EE Version Requirement for Multiple Connection and View Designer Features
To use the multiple connection and View Designer features described below, ensure that the Oracle Business Intelligence Enterprise Edition 11.1.1.7.140527 patch or higher is installed. Go to My Oracle Support, Patches & Updates tab, and search by "Product or Family." In the Product field, select Oracle Business Intelligence Enterprise Edition; in the Release field, select OBI EE 11.1.1.7.140527.
Multiple connections are supported with Oracle BI EE version 11.1.1.7.140527 and higher. If connecting to earlier versions of Oracle BI EE, then only one connection is allowed.
To use the Oracle BI EE View Designer feature (introduced in the 11.1.2.5.200 release), the Oracle BI EE 11.1.1.7.140527 patch or higher is required.
You should only use the View Designer in Oracle Smart View for Office to edit views that were created and inserted using the View Designer.
See "Editing Views Created in View Designer" in the Oracle® Smart View for Office User's Guide for more information.
