Formatting Options Supported for Financial Management Forms and Ad Hoc
Table 4-16 Formatting Options Supported for Financial Management Forms and Ad Hoc
Option | Forms | Ad Hoc |
Yes | Yes | |
Use Cell Styles | Yes | Yes |
Use Excel Formatting
—Move Formatting on Operations |
No | Yes |
Retain Numeric Formatting | Yes | Yes |
Adjust Column Width and Row Height | Yes | Yes |
Freeze Row and Column Headers | Yes | No |
Scale | Yes | Yes |
Use Custom Number Format | Yes | Yes |
Use Thousands Separator | Yes | Yes |
Decimal Places | Yes | Yes |
Negative Number Format | Yes | Yes |
Repeat Member Labels | Yes | Yes |
Show Distinct Page Member Names | Yes | Yes |
