Connecting Using a Shared Connection
Use the procedure in this topic to connect to supported data sources using a shared connection.
To connect to a data source using a shared connection:
From the Smart View ribbon, click
Panel.
To open a recently used item, click an item under Recently Used, and then skip to step 3. You can click
to pin items to this list.
- From the Smart View Panel or from the drop-down menu displayed when you click the down arrow next to
, select Shared Connections.
Users of Smart View with Office 365 on a Windows machine, who are also provisioned as Smart View (Mac and Browser) users: If more than one Smart View ribbon tab appears in Office, and an error message is displayed in the panel, ensure that you launch the panel from the correct ribbon tab, as described in Ribbon Tab for Smart View (Mac and Browser) Displays in Smart View on Windows in the Oracle Smart View for Office Installation and Configuration Guide.
- In the Connect to Data Source dialog or the Login dialog, enter your user name and password.
When accessing a cloud data source, the business process domain name appears next to Welcome in the Login dialog. If you need to change domains, click the change domain link, enter the new cloud Identity Domain name, and click Go. Then proceed with entering your user name and password.
Depending on how your administrator configured Oracle Smart View for Office, you may or may not be required to enter your user name and password as you change data providers and Office applications.
- In the Shared Connections panel, in the field labeled Select Server to proceed, select a data source type from the drop-down menu.
Once you select a data source type, the connections available for the selected data source are displayed in a tree list in the Smart View Panel.
- In the Smart View Panel, navigate the tree list, and then double-click the item—form, ad hoc grid, Smart Slice, task list, or catalog—that you want to open.
You can also open items by right-clicking them and making a selection; or selecting an option from the Action Panel at the bottom of the Smart View Panel.
- Optional: After the item is opened on the grid, to easily locate it in the tree view, click the arrow next to
and select Locate Worksheet Connection.Note:
Depending on how the administrator configured Smart View, you may or may not be required to enter your user name and password as you change data providers and Office applications.
