Discrepancy in Results Between Notification Messages and Applications or Watchlists
If users are seeing a different number of records in their notification message than in the associated application or Watchlist, this could be the result of the notification being run as a proxy user rather than as the subscriber. In other words, the notification designer did not enable the Run as Subscriber option when creating the notification. If the data security settings differ between the proxy user (the person who started the notification job on the AIS Server) and the subscriber, this discrepancy can occur. If you decide not to use the Run As Subscriber option for a particular notification, consider any security implications and data discrepancies. Although running as a proxy user may improve performance, it can also create discrepancies in results. Because each notification is unique to your organization, you must decide what is appropriate on a case-by-case basis.
