Defining the SQL Package Creation Location
Verify the JDE.INI setting on the Enterprise Server that controls where SQL Packages are created. The applicable setting is:
[DB SYSTEM SETTINGS] sqlPackageLibrary=value
where value
must be set to 2 in order for Table Conversions to work
correctly. Otherwise you will see Table Conversion failures. For an explanation of other
values, refer to UBE Performance ' SQL Package Location in the chapter of this
guide entitled: Performing Post Installation and Upgrade Tasks.
