UBE Performance ' SQL Package Location
Once the Table Conversions are completed, change the jde.ini setting on the Enterprise Server that controls where SQL Packages are created. The applicable setting is:
[DB SYSTEM SETTINGS] sqlPackageLibrary=value
where value
controls the location where JD Edwards EnterpriseOne will place
SQL packages on your IBM i-based Enterprise Server.
This is shipped with a value of 2 in order for Table Conversions to work correctly. You must change this value to 0 or 1 otherwise you will see a negative performance impact on UBEs. Values are listed in this table:
Value |
Action |
0 |
Indicates the system to create packages in the library defined in this jde.ini section: [INSTALL] DefaultSystem=e1_system where
for JD Edwards EnterpriseOne
Release 9.2 the default value for
1 |
Indicates the system will create packages in QRECOVERY and that UBE packages will be named Rnnnnn. Caution: You will need to delete any old UBE SQL packages in QRECOVERY. Please note that no UBEs can be running on the server while you are deleting these packages. |
2 |
Indicates the system will create packages in QRECOVERY and that UBEs are assigned unique names (job number). For example, a UBE name will be in the format T123456. Note: You can use this setting for normal daily operations. However it will make the startup for your frequently run UBEs a little slower as they will not be able to use existing SQL packages. |
