Working with SETOWAUT
SETOWAUT is a set of tools you can use to secure JD Edwards EnterpriseOne objects on your IBM i Enterprise Server. The SETOWAUT objects are delivered in a SAVF by the same name in the JDEOW library. However, it is recommended that you download the latest version of SETOWAUT from the Update Center.
This file can be restored using the RSTLIB command. It should be restored to a library called SETOWAUT. Instructions for using SETOWAUT are found in the JD Edwards EnterpriseOne Tools Server and Workstation Administration Guide.
