Merging Specification Tables
To merge your specification tables:
![This image is described in the surrounding text.](images/spec_table_merge_workbench.png)
On Specification Table Merge Workbench, choose Merge All from the Form menu.
If you are installing an alternate language, the Plan Name field on the Specification Table Merge Workbench form will contain the name of your language plan.
After the merge finishes, verify the output of the report that is produced.
