Retrofitting Custom Modifications
To retrofit custom modifications:
From the Development Client on which you will retrofit the object modifications, check out the modified objects.
To check out objects, see JD Edwards EnterpriseOne Tools Object Management Workbench for the Web Guide.
http://docs.oracle.com/cd/E24705_01/doc.91/e24255/toc.htm
Use the ER Compare utility to compare the upgraded version of the object on the client machine to a version of the object as it was before the upgrade.
This tool enables the direct copy of event rules from the original specifications to the upgraded specifications. See the section of the JD Edwards EnterpriseOne Tools Software Updates Guide entitled: JD Edwards EnterpriseOne ER Compare for more information about this procedure.
http://docs.oracle.com/cd/E24705_01/doc.91/e24260/compare_tools.htm#BABDEDHF
Use the other design tools described in the JD Edwards EnterpriseOne Development Tools Guides to retrofit other modified components of objects.
Use ER Compare to show the difference in named event rule (NER) business function source codes.
Redo any custom event rules for Do Initialize events because they have been removed from the UBE event list.
When you have tested and retrofitted the modifications, check them back in and rebuild the package.
Test and fix the modifications, and then rebuild and re-deploy the corrected package.
Repeat this step until all the modifications are functioning properly.
