Using JD Edwards Compare and Merge Tools
The chapter entitled: Using JD Edwards Compare and Merge Tools in the JD Edwards EnterpriseOne Software Updates Guide fully describes all of the tools that have been created to help you compare between releases as well as with environments on the same release.
See Also
http://docs.oracle.com/cd/E24705_01/doc.91/e24260/toc.htm
The following sections in this guide provide a high-level description of the compare and merge tools:
