Using the Customization Object Analyzer
If you are on an older release of JD Edwards EnterpriseOne, you need to identify customizations in order to determine the impact and level of effort to retrofit the customizations into the newer release of JD Edwards EnterpriseOne. This utility helps to identify the customizations in order to determine the impact and level of effort to retrofit the customizations into the newer release of JD Edwards EnterpriseOne. A review of this information, prior to performing modifications within the software, will allow for a smoother and more predictable upgrade of the EnterpriseOne software.
The Customization Object Analyzer is comprised of a UBE that loads a table and UBEs that read from that table to create either a summary or detailed report. The UBEs are:
  • R9840DL (Object Dataload)
    This UBE loads the F98881CU table in a parent-child hierarchy of object changes with a list of all JD Edwards EnterpriseOne customized objects.
  • RD9840RS (Object Customization Summary Report - BI Publisher)
    This UBE creates a summary report from the data in the F98881CU table.
  • RD9840RD (Object Customization Detail Report - BI Publisher)
    This UBE creates a detail report from data in the F98881CU table that shows the details of the customizations grouped by various criteria.
  • R9840R (Object Customization Summary and Detail Report - Standard Version)
    This UBE creates a summary and detail report from the data in the F98881CU table.
See Also
