Using the Application Configuration Analyzer
The Application Configuration Analyzer is a set of reports which identify differences for processing options, data dictionary (DD) items, and user defined codes (UDCs) between releases or environments. These reports are:
  • Versions Compare Report
  • User Defined Codes Compare Report
  • Data Dictionary Compare Report
If you have made custom modifications to business data, these reports can help you verify that your modifications were carried forward to the new release. You can use these tools anytime you want to compare items between two environments.
See Also
