Running the Impact Analysis Report (R96711)
Note: For Release 9.2, the Package Name for a Simplified Upgrade Impact Analysis Report will always be 920. However, multiple packages with the same name can be created for multiple environments.
To run the Impact Analysis Report (R96711), select Simplified Upgrade Impact Analysis (P96711) from the Advanced Operations Menu (GH9611).
This image is described in the surrounding text.
From the Simplified Upgrade Impact Analysis Master, you can highlight an existing report and use form exits to perform these functions:
  • Reanalyze
    Reloads the manifest and reruns the Impact Analysis Report.
  • Object View
    Displays the Impact Analysis Report with a list of all details of all objects that will be affected by the Simplified Upgrade including the merge action such as change, replace, add, or delete.
    For a description of the these objects or groups of objects, refer to the section of this chapter entitled: Using the Simplified Upgrade Impact Analysis Program (P96711).
  • Analysis Summary Report
    Displays a statistical summary of the types and number of objects that will be impacted by the Simplified Upgrade.
  • Analysis Report (R96701)
    Creates a detailed report that includes each object that will be impacted by the Simplified Upgrade.
Example - Analysis Report (R96701) - (1 of 2)
The following screen shows an example of an Analysis Summary Report (R96701).
Example - Analysis Report (R96701) - (2 of 2)
