Selecting Languages
To select languages:
![This image is described in the surrounding text.](images/language_select.png)
On Language Selection, to set up a language for the selected environment, choose the appropriate language.
From the Row menu, click Select.
Repeat the above steps until all your languages have been selected.
Click OK.
Tip: Customization Considerations. If you have customizations that you do not want to merge, you can prevent individual conversions and merges from running by changing their status or deleting the appropriate records from the plan before you run the Installation Workbench.
