Verifying Advanced Parameters
If you turned off Default Advanced Parameters on the Environment selection form, the Advanced Parameters form appears.
To verify advanced parameters:
This image is described in the surrounding text.
  1. On Advanced Parameters, complete the following fields and turn on the following options:
    Field
    Description
    Logic Data Source
    The server data source where the table conversions will run
    Table Conversion Throttle
    The number of table conversions to be run concurrently on the server
    For the PD920 environment, by default the Specifications Merge checkbox is not enabled. If you want to run the Specifications Merge for this environment, you must enable the Specifications Merge checkbox.
    The Table Conversion Workbench checks the maximum jobs for the default job queue for the logic server. It will only submit up to the number of maximum jobs on the queue to run at once. If the throttle is set higher than the queue, it uses the queue maximum number of jobs. If the queue is set higher than the throttle, it uses the throttle.
  2. Click the OK button.
    If you turned off Default Languages on the Select Environments selection form, continue with Selecting Languages (optional).
    If you are not installing languages, Release 9.2 prompts you for data source information. Skip to Setting Up Environment Data Sources.
