Understanding This Guide
This guide is designed to direct you through a basic JD Edwards EnterpriseOne upgrade including the Traditional and Simplified Upgrades. It is not a substitute for the database administration manuals provided by your Relational Database Management System (RDBMS) vendor, the network administration manuals provided by your network vendor, or the installation and configuration manuals for third-party products used with JD Edwards EnterpriseOne.
Tip: All links in this guide are "live" (clickable) in the HTML version of this document.
This guide is designed for management information system (MIS) managers and installers. It outlines the procedures for upgrading to Release 9.2. To successfully follow these procedures you must understand:
  • Hardware and software requirements
  • Database setup and management
  • Enterprise platforms and operating systems
At a minimum, review these guides before beginning:
In addition, it is recommended to complete the database product courses that your database vendors provide.
Below are links to the documentation libraries on the Oracle Technology Network (OTN) for the three major categories of JD Edwards EnterpriseOne:
  • JD Edwards EnterpriseOne Applications Documentation Release 9.2
    http://docs.oracle.com/cd/E64610_01/index.htm
  • JD Edwards EnterpriseOne Tools Documentation Release 9.2
    http://docs.oracle.com/cd/E53430_01/index.htm
  • JD Edwards EnterpriseOne Install and Upgrade Documentation Release 9.2
    http://docs.oracle.com/cd/E61420_01/index.htm
