Understanding Upgrade Types
Beginning with Tools Release 9.2, two types of Upgrades are available:
Note: Unless specifically noted, all topics and procedures in this Upgrade guide are applicable to both the Traditional and Simplified Upgrade types.
Caution: Regardless of which upgrade type you choose, the end result of either upgrade process is identical in terms of the functional code base applicable to JD Edwards EnterpriseOne Applications Release 9.2.
