Verifying Advanced Parameters
If you turned off Default Advanced Parameters on the Environment selection form, the Advanced Parameters form appears.
To verify advanced parameters:
On Advanced Parameters, complete these fields and turn on the following options:
Field
Description
Logic Data Source
Displays the server data source where the table conversions will run
Table Conversion Throttle
Displays the number of table conversions to be run concurrently on the server
Note:The Table Conversion Workbench checks the maximum jobs for the default job queue for the logic server. It will only submit up to the number of maximum jobs on the queue to run at once. If the throttle is set higher than the queue, it uses the queue maximum number of jobs. If the queue is set higher than the throttle, it uses the throttle.
Click the OK button.
If you are not installing languages, you are prompted to enter data source information.
If you turned off Default Languages on the Select Environments selection form, continue with the next task.
