Setting Up Environments
By default, Release 9.2 configures your system using values for typical environments. Depending on the options chosen when you set up your plan, Release 9.2 displays one or more of the following parameters, which you can customize in the following tasks:
Environments
Data Load Options
Advanced Parameters
Languages
You can customize any of these parameters by turning off the default option on the Environment Selection form. As you move through the plan, Release 9.2 will display a customization form for each parameter that you turn off.
![This image is described in the surrounding text.](images/environment_select_up.gif)
On Environment Selection, turn off the options for those parameters that you want to customize.
Note: The parameters that display might vary depending on which options you chose at the beginning of the planning process.Click the OK button.
Note: If you checked the default option for all parameters, skip to Setting Up Environment Data Sources.Use the following tasks to customize each of the parameters listed above. Release 9.2 displays customization forms only for those parameters for which were turned off the default options. Skip the tasks for those parameters that were left turned on.
Continue with the following relevant tasks:
