(HUN)Setting Up Your System to Issue a Document in Lieu of an Invoice
This table gives a high-level overview legal document setup for documents in lieu of an invoice.
Program |
Action |
Legal Document Type (P7400002) |
Complete these fields:
Complete the other fields as your business process requires. |
Legal Doc. Type / Doc Type Relation (P7400003) |
Print Template Definition (P7430021) |
Complete the other fields as your business practice requires. Set up the line types for documents in lieu of an invoice. |
Issue Place (P7400004) |
Set up codes for the locations from which you will issue the document in lieu of an invoice. If you issue documents from only one location, you do not need to complete this setup. |
Print Template/Legal Doc. Type Relation (P7430023) |
Associate the print template that you created for documents in lieu of invoices with the legal document type that you created for documents in lieu of invoices. |
Legal Document Next Number (P7400001) |
Set up the next numbers for the document type that you created for documents in lieu of an invoice. You can also specify whether the document in lieu of an invoice shares a numbering scheme with another document type. |
Legal Document / Print UBEs Relation (P7430024) |
Associate the legal document type that you set up for documents in lieu of an invoice with the version of the print program that you use to generate the legal document. For example, you might set up a version of the Print Invoice - Hungary - SOP/AR program (R74H3040) program to use to print documents in lieu of invoices, and specify that program and version. |
User-Defined Codes (P0004A) |
Add the document type code that you set up for documents in lieu of invoices to the 74/PT UDC table to specify the text to print as the name of the document. For example, if you named the document type for documents in lieu of invoices LIEU, enter LIEU in the codes field and enter the text to print as the title of the document in the Description 01 field. |
PO - Print Legal Document from Sales Order (P7420565) |
Set up a version of the PO - Print Legal Document from Sales Order program (P7420565) to use for documents in lieu of invoices, and set up a corresponding version of the Print Invoices (R42565) program. |
