Regenerating and Reinstalling Self-Signed Certificates for One-Click Provisioning
This section shows you how to regenerate and reinstall Self-Signed Certificates for One-Click Provisioning.
Prerequisite
You must have an installation of Java Keystore.
Generating Self-Signed Certificates on Linux
Use this procedure to generate self-signed certificates on Linux.
- Log into Provisioning Server.
- Run the following commands (where each bulleted item is one contiguous line):
sudo -imv /u01/jde920/.vm_unconfigured /u01/jde920/vm_unconfigured/u01/jdk1.8.0/jre/bin/keytool -delete -alias cert -keystore "/u01/jdk1.8.0/jre/lib/security/cacerts" -storepass *****/u01/CertGen/ConfigureCertKey_CC.sh/u01/CertGen/ConfigureCertKey_SMC.sh <WebLogic Admin Password>mv /u01/jde920/vm_unconfigured /u01/jde920/.vm_unconfigured
Note:- The
storepassvalue ***** in above commands is the WebLogic Admin password. - The
generated cert.pemfile is located in:/u01/E1CloudConsole/keys - The log file path is:
/var/log
Importing the Self-Signed Certificate into Target Machines on Linux
The self-signed certificate file that you generated in the previous steps must be imported into these target machines that were deployed by JD Edwards EnterpriseOne One-Click Provisioning:
- HTML Server
- Enterprise Server
- Oracle Database Server
HTML Server
Use this procedure to import the self-signed certificate into the HTML Server.
- Run this command:
sudo -i -
Get the
cert.pemfile from Provisioning Server, which you generated in the previous procedure in this section entitled: "Generating Self-Signed Certificates on Linux". -
Use this command is determine if a certificate with an alias of smcert is already imported to
jdk/jre/lib/security/cacerts, where this command is a single contiguous line:/u01/jde_home/SCFHA/jdk/jre/bin/keytool -list -v -alias smcert -keystore "/u01/jde_home/SCFHA/jdk/jre/lib/security/cacerts" -storepass *****If the results of the above command indicate that an alias of smcert certificate is already imported to the JDK/JRE lib location, use this command to remove it, where this command is a single contiguous line:
/u01/jde_home/SCFHA/jdk/jre/bin/keytool -delete -file cert.pem -alias smcert -keystore "/u01/jde_home/SCFHA/jdk/jre/lib/security/cacerts" -storepass *****Note: The storepass value ***** in above commands is the default password for Java trustStore. -
Use these commands to import the certificate that you generated in the previous procedure of this section entitled: "Generate Self-Signed Certificates" to
/u01/jde_home/SCFHA/jdk, where each command is a single contiguous line:/u01/jde_home/SCFHA/jdk/jre/bin/keytool -import -file cert.pem -alias smcert -keystore "/u01/jde_home/SCFHA/jdk/jre/lib/security/cacerts" -storepass *****/u01/jde_home/SCFHA/jdk/jre/bin/keytool -list -v -alias smcert -keystore "/u01/jde_home/SCFHA/jdk/jre/lib/security/cacerts" -storepass *****Note: The storepass value ***** in above commands is the default password for Java trustStore. -
Use this command is determine if a certificate with an alias of smcert is already imported for the JDK path:
/u01/oracleJDE/jdk_path/jre/bin/keytool -list -v -alias smcert -keystore "/u01/oracleJDE/jdk_path/jre/lib/security/cacerts" -storepass *****If the results of the above command indicate that an alias of smcert certificate is already imported, use this command to remove it, where this command is a single contiguous line:
/u01/oracleJDE/jdk_path/jre/bin/keytool -delete -alias smcert -keystore "/u01/oracleJDE/jdk_path/jre/lib/security/cacerts" -storepass *****Note: The storepass value ***** in above commands is the WebLogic Admin password. -
Use these commands to import the certificate that you generated in the previous procedure of this document entitled: "Generate Self-Signed Certificates" to /u01/oracleJDE/jdk_path, where each command is a single contiguous line:
/u01/oracleJDE/jdk_path/jre/bin/keytool -import -file cert.pem -alias smcert -keystore "/u01/oracleJDE/jdk_path/jre/lib/security/cacerts" -storepass *****/u01/oracleJDE/jdk_path/jre/bin/keytool -list -v -alias smcert -keystore "/u01/oracleJDE/jdk_path/jre/lib/security/cacerts" -storepass *****Note: The storepass value ***** in above commands is the WebLogic Admin password.
Enterprise Server
- Run this command:
sudo -i -
Get the
jdk/jre/lib/security/cacerts, where this command is a single contiguous line:/u01/jde920/jde_home/SCFHA/jdk/jre/bin/keytool -list -v -alias smcert -keystore "/u01/jde920/jde_home/SCFHA/jdk/jre/lib/security/cacerts" -storepass *****If the results of the above command indicate that an alias of smcert certificate is already imported, use this command to remove it, where this command is a single contiguous line:
/u01/jde920/jde_home/SCFHA/jdk/jre/bin/keytool -delete -alias smcert -keystore "/u01/jde920/jde_home/SCFHA/jdk/jre/lib/security/cacerts" -storepass *****Note: The storepass value ***** in above commands is the default password for Java trustStore. -
Use these commands to import the certificate that you generated in the previous procedure of this section entitled: Generate Self-Signed Certificates to
/u01/jde920/jde_home/SCFHA/jdk, where each command is a single contiguous line:/u01/jde920/jde_home/SCFHA/jdk/jre/bin/keytool -import -file cert.pem -alias smcert -keystore "/u01/jde920/jde_home/SCFHA/jdk/jre/lib/security/cacerts" -storepass *****/u01/jde920/jde_home/SCFHA/jdk/jre/bin/keytool -list -v -alias smcert -keystore "/u01/jde920/jde_home/SCFHA/jdk/jre/lib/security/cacerts" -storepass *****Note: The storepass value ***** in above commands is the default password for Java trustStore. -
/u01/jdk8_32/jre/bin/keytool -list -v -alias smcert -keystore "/u01/jdk8_32/jre/lib/security/cacerts" -storepass *****If the results of the above command indicate that an alias of smcert certificate is already imported, use this command to remove it, where this command is a single contiguous line:
/u01/jdk8_32/jre/bin/keytool -delete -alias smcert -keystore "/u01/jdk8_32/jre/lib/security/cacerts" -storepass *****Note: The storepass value ***** in above commands is the Site Key password. -
/u01/jdk8_32, where each command is a single contiguous line:/u01/jdk8_32/jre/bin/keytool -import -file cert.pem -alias smcert -keystore "/u01/jdk8_32/jre/lib/security/cacerts" -storepass *****/u01/jdk8_32/jre/bin/keytool -list -v -alias smcert -keystore "/u01/jdk8_32/jre/lib/security/cacerts" -storepass *****Note: The storepass value ***** in above commands is the Site Key password.
Database Server
Use this procedure to import the self-signed certificate into the Oracle Database Server. Note that is only applicable if you are using Oracle Compute service for your Database Server; it not applicable if you are using the Oracle Database Service (DBS).
- Log into the Oracle Compute Database Server.
- Get the cert.pem file from Provisioning Server, which you generated in the previous procedure in this section entitled: "Generating Self-Signed Certificates on Linux".
- Run this command:
sudo -i -
Use this command is determine if a certificate with an alias of smcert is already imported to jdk/jre/lib/security/cacerts, where this command is a single contiguous line:
/u01/jde_home/SCFHA/jdk/jre/bin/keytool -list -v -alias smcert -keystore "/u01/jde_home/SCFHA/jdk/jre/lib/security/cacerts" -storepass *****If the results of the above command indicate that an alias of smcert certificate is already imported, use this command to remove it, where this command is a single contiguous line:
/u01/jde_home/SCFHA/jdk/jre/bin/keytool -delete -alias smcert -keystore "/u01/jde_home/SCFHA/jdk/jre/lib/security/cacerts" -storepass *****Note: The storepass value ***** in above commands is the default password for Java trustStore. -
Use these commands to import the certificate that you generated in the previous procedure of this document entitled: "Generate Self-Signed Certificates" to /u01/jde_home/SCFHA/jdk, where each command is a single contiguous line:
Generating Self-Signed Certificates on Microsoft Windows
Use this procedure to generate self-signed certificates on Microsoft Windows.
- Open Windows Powershell As Administrator.
- Run the following commands, where each command is a single contiguous
line:
ren <drive>\JDE\PP\jde920\.vm_unconfigured <drive>\JDE\PP\jde920\vm_unconfigured<drive>\JDE\jdk1.8_64\jre\bin\keytool -delete -alias cert -keystore "<drive>\JDE\jdk1.8_64\jre\lib\security\cacerts" -storepass *****Note: The storepass value ***** in above command is the WebLogic Admin password.$env:OPENSSL_CONF += "C:\JDE\bin\openssl.cnf"<drive>\JDE\PP\CertGen\ConfigureCertKey_CC.ps1<drive>\JDE\PP\CertGen\ConfigureCertKey_SMC.ps1 <WebLogic Admin Password>ren <drive>\JDE\PP\jde920\vm_unconfigured <drive>\JDE\PP\jde920\.vm_unconfigured
Importing the Self-Signed Certificate into Target Machines on Microsoft Windows
The self-signed certificate file that you generated in the previous steps must be imported into these target machines that were delivered by JD Edwards EnterpriseOne One-Click Provisioning:
- All Servers
- HTML Server
- Enterprise Server
All Servers
Use this procedure to import the self-signed certificate into all Microsoft Windows servers.
- Log into the each Microsoft Windows server.
- Get the
cert.pemfile that is located on the Provisioning Server. You generated this key using the previous procedure in this section entitled: "Generating Self-Signed Certificates on Microsoft Windows".On the Provisioning Server, this file is located at this location:
<drive>\JDE\PP\E1CloudConsole\keys -
On each machine, use this command is determine if a certificate with an alias of smcert is already imported to
<drive>\JDE\jde_home\SCFHA\jdk, where this command is a single contiguous line:<drive>\JDE\jde_home\SCFHA\jdk\jre\bin\keytool -list -v -alias smcert -keystore"<drive>\JDE\jde_home\SCFHA\jdk\jre\lib\security\cacerts" -storepass *****If the results of the above command indicate that an alias of smcert certificate is already imported, use this command to remove it, where this command is a single contiguous line:
<drive>\JDE\jde_home\SCFHA\jdk\jre\bin\keytool -delete -alias smcert -keystore "<drive>\JDE\jde_home\SCFHA\jdk\jre\lib\security\cacerts" -storepass *****Note: The storepass value ***** in above commands is the default password for Java trustStore. -
On each machine, use these commands to import the certificate that you generated in the previous procedure of this section entitled: "Generate Self-Signed Certificates" to
<drive>\JDE\jde_home\SCFHA\jdk, where each command is a single contiguous line:<drive>\JDE\jde_home\SCFHA\jdk\jre\bin\keytool -import -file cert.pem -alias smcert -keystore "<drive>\JDE\jde_home\SCFHA\jdk\jre\lib\security\cacerts" -storepass *****<drive>\JDE\jde_home\SCFHA\jdk\jre\bin\keytool -list -v -alias smcert -keystore"<drive>\JDE\jde_home\SCFHA\jdk\jre\lib\security\cacerts" -storepass *****Note: The storepass value ***** in above commands is the default password for Java trustStore.
HTML Server
- Log into the HTML server.
- Get the
C:\Program Files\Java\jdk1.8.0_201, where this command is a single contiguous line:<JDK_path>\jre\bin\keytool -list -v -alias smcert -keystore "<JDK_path>\jre\lib\security\cacerts" -storepass *****If the results of the above command indicate that an alias of smcert certificate is already imported, use this command to remove it, where this command is a single contiguous line:
<JDK_path>\jre\bin\keytool -delete -alias smcert -keystore "<JDK_path>\jre\lib\security\cacerts" -storepass *****Note: The storepass value ***** in above commands is the WebLogic Admin password. -
Use these commands to import the certificate that you generated in the previous procedure of this document entitled: "Generate Self-Signed Certificates" to C:\Program Files\Java\jdk1.8.0_201 , where each command is a single contiguous line:
<JDK_path>\jre\bin\keytool -import -file cert.pem -alias smcert -keystore "<JDK_path>\jre\lib\security\cacerts" -storepass *****<JDK_path>\jre\bin\keytool -list -v -alias smcert -keystore "<JDK_path>\jre\lib\security\cacerts" -storepass *****Note: The storepass value ***** in above commands is the WebLogic Admin password.
Enterprise Server
- Log into the Enterprise Server.
- Get the
Use this command is determine if a certificate with an alias of smcert is already imported to <drive>\JDE\jdk8_32, where this command is a single contiguous line:
<drive>\JDE\jdk8_32\jre\bin\keytool -list -v -alias smcert -keystore "<drive>\JDE\jdk8_32\jre\lib\security\cacerts" -storepass *****If the results of the above command indicate that an alias of smcert certificate is already imported, use this command to remove it, where this command is a single contiguous line:
<drive>\JDE\jdk8_32\jre\bin\keytool -delete -alias smcert -keystore"<drive>\JDE\jdk8_32\jre\lib\security\cacerts" -storepass *****Note: The storepass value ***** in above commands is the Site Key password. -
Use these commands to import the certificate that you generated in the previous procedure of this document entitled: "Generate Self-Signed Certificates" to <drive>\JDE\jdk8_32, where each command is a single contiguous line:
<drive>\JDE\jdk8_32\jre\bin\keytool -import -file cert.pem -alias smcert -keystore"<drive>\JDE\jdk8_32\jre\lib\security\cacerts" -storepass *****<drive>\JDE\jdk8_32\jre\bin\keytool -list -v -alias smcert -keystore "<drive>\JDE\jdk8_32\jre\lib\security\cacerts" -storepass *****Note: The storepass value ***** in above commands is the Site Key password.
