Setting Up Compound Components
Access the Component Code Cross Reference Revisions form.
On Component Code Cross Reference Revisions, select each component calculation rule that you want to include in the cross-reference, and then select Add Cross Reference from the Row menu.
You can include only previously defined component calculation rules in cross-reference information.
The system marks the component calculation rules that include cross-reference information with an X in the X Ref column on the Component Table Revisions form.
