Calculating Gain or Loss for Received Products
Access the Four Point Analysis form.
T T (type of temperature)
Enter a code that specifies the type temperature. Values are:
F: Fahrenheit
C: Celsius
Density
Enter the company's standard for density. You can also use this field for pack size and weight information.
D T (density type)
Enter a code used to identify the type of density. Values are:
A: Absolute Density
G: API Specific Gravity
R: Relative Density
Density Temp (density temperature)
Enter the temperature at which the density was measured. The system uses the density temperature type from Branch/Plant Constants - Page 3 Row exit.
T U (type of temperature)
F; Fahrenheit
C: Celsius
