Volume Calculation for a Simultaneous Movement
You can calculate volume for a simultaneous movement, such as simultaneously receiving and withdrawing product from the same tank.
When you calculate volume from dip readings, you can also record the meter readings from a withdrawal of product. When you enter these readings, the system adds the quantity that you withdraw back into the quantity calculated from the dip readings. A message appears to indicate that a simultaneous withdrawal occurred.
You cannot calculate volume for a simultaneous movement if you select Dip Volume Calculator from the Bulk Stock Management menu.
You must record any gain or loss associated with this type of transaction to the outturn gain/loss.
See Recording a Gain or Loss on an Intra-Depot Stock Movement.
