Serial Number Entry During Order Entry
If you enter an order for an item that has a lot process type and that indicates that a serial number is required, you must enter a valid location and serial (lot) number during order entry.
These rules apply if a serial number is required during sales order entry:
The transaction unit of measure must be the same as the primary unit of measure for the serialized item.
The quantity must be equal to one when you enter a location/serial number combination.
You must enter a valid and available location/serial number combination.
You might receive an error because a location/serial number and item combination that you enter is not available or because the quantity on hand is zero. Serial numbers are unavailable if the quantity for the item/location/serial number combination is:
In inspection
In operation 1
In operation 2
In transit
If an item is returned for credit or repair, you must enter a valid location and serial number. Alternatively, you can use the serial number information to inquire on the existing order.
