Setting Processing Options for Voucher Match Automation UBE for Automation Rule 02, 03, 04, 05 (R4304020)
Processing options enable you to specify default processing values.
Note: The Voucher Match Automation UBE for
Automation Rule 02, 03, 04, 05 program does not appear on a menu because you do not
directly run the program. Instead, the Voucher Match Automation Driver program runs
the Voucher Match Automation UBE for Automation Rule 02, 03, 04, 05 program as part
of the voucher match automation process. Access the processing options for the
Voucher Match Automation UBE for Automation Rule 02, 03, 04, 05 program from the
Batch Versions program (P98305W). You can enter BV in the Fast Path to access
the Batch Versions program.
These processing options apply to automation rules 02, 03, 04, and 05. To apply different processing option values to the records processed under different automation rules, you must:
Set up multiple versions of the R4304020 program.
Set up multiple versions of the R4304010 program.
Assign each version of the R4304020 program to a different version of the R4304010 program.
Run each version of the R4304010 program.
