Setting Processing Options for Voucher Match Automation UBE for Automation Rule 01 (R4304016) and Voucher Match Automation UBE for Automation Rule 06 (R4304021)
Processing options enable you to specify default processing values.
Note: The Voucher Match Automation UBE for
Automation Rule 01 and Voucher Match Automation UBE for Automation Rule 06 programs
do not appear on a menu because you do not directly run the programs. Instead, the
Voucher Match Automation Driver program runs the programs as part of the voucher
match automation process. Access the processing options for the Voucher Match
Automation UBE for Automation Rule 01 and Voucher Match Automation UBE for
Automation Rule 06 programs from the Batch Versions program (P98305W). You can enter
BV in the Fast Path to access the Batch Versions program.
