Evaluation Management System (EMS) Category Rules
Rules in the following category are delivered as examples to demonstrate the use of an automated rating scheme as part of an Evaluation. All Rules created which interact with the Evaluation records should be built under this category to take advantage of the delivered data sets and Rule group which support Rules processing for Evaluations.
Rule ID Name Long Description
SCC_RULE_ID_20140306170755
Rating Scheme Calculation Example
This Rule can be used at the Evaluation Rating Scheme level as an alternate calculation of the Overall Rating value for the scheme. This example returns the sum of the component rating values.
SCC_RULE_ID_20140303114951
Test Score Rule Example
This Rule returns a rating value for the rating component based upon the highest score value in a comparison of ACT scores and SAT I scores. Calls a number of Rules to get the scores from the test score records, evaluate those results against a rating scale to obtain the rating value to populate the rating component.
SCC_RULE_ID_20140306173039
Academic Qualification Example
This Rule returns a rating value to the rating component based upon education data fields of percentile rank and converted GPA contained in External Academic Summary. Calls a number of other Rules which get the GPA and percentile values, evaluate those results against a rating scale to obtain the rating value to populate the rating component.
SCC_RULE_ID_20140306172622
Courses Completed Requirement Example
This Rule returns a rating value to the rating component based on a count of completed subjects in External Academic Subjects.
SCC_RULE_ID_20140304120320
Get ACT Rating Value Example
Returns the rating value for an ACT score.
SCC_RULE_ID_20140306141320
Get Course Count Rating Example
Gets the rating value for Course Count.
SCC_RULE_ID_20140306143945
Get Course Requirement Rating Example
Returns a rating value based on the number of Courses Completed for all Academic History entries that have External Academic Data rows where External Career = HS and Transcript Type = OFF.
SCC_RULE_ID_20140306161125
Get Courses Completed Count Example
Returns a count of completed courses in External Academic Subjects.
SCC_RULE_ID_20140304123947
Get GPA Rating Example
Returns the rating value for a GPA.
SCC_RULE_ID_20140304162158
Get High School Rating Example
Gets the highest rating value of the Converted GPA and Percentile values and passes to Get High School Rating Driver Rule.
SCC_RULE_ID_20140304170413
Get High School Rating Driver Example
Loops through External Academic Data where External Career = HS for an EMPLID and calls Get High School Rating. Returns the highest High School Rating.
SCC_RULE_ID_20140226160705
Get Highest Test Component Score Example
Returns the highest score for the specified EMPLID, TEST_ID, and TEST_COMPONENT.
SCC_RULE_ID_20140304155504
Get Percentile Rating Example
Returns the rating value for a Percentile Rank.
SCC_RULE_ID_20140304121526
Get SAT I Rating Value Example
Returns a rating value for a SAT I Test Score Total.
SCC_RULE_ID_20140226155857
Get Test Component Scores Example
Returns a list of test component scores for the specified EMPLID, TEST_ID and TEST_COMPONENT.
