Setting 3C Engine Security
This section provides an overview of 3C engine security and discusses how to assign engine event 3C groups.
Understanding 3C Engine Security
You use 3C groups to set security for 3C engine events just as you do to set security for communications, checklists, and comments outside of the scope of the 3C engine. A user can then trigger only the events within the 3C group to which he or she is assigned. When the trigger is invoked online, the PeopleCode function assigns only those engine events for which that user has inquiry or update access. If the user does not have security access for the engine event, the system ignores the assignment.
Page Used to Set 3C Engine Security
Page Name Definition Name Navigation Usage
Event 3C Groups
EVNT_GRP_3C_TABLE
Campus Community, and then 3C Engine, and then Set Up 3C Engine, and then Event 3C Groups
Assign engine event 3C groups to assign security to 3C engine event definitions.
Assigning Engine Event 3C Groups
Access the Event 3C Groups page (Campus Community, and then 3C Engine, and then Set Up 3C Engine, and then Event 3C Groups).
This example illustrates the fields and controls on the Event 3C Groups page. You can find definitions for the fields and controls later on this page.
Add the groups that should have security access to this event ID.
See Campus Solutions Application Fundamentals: Setting Up 3C Group Security.
