Setting Up Adapters
This section discussesSetting Up Adapters.
Page Used to Set Up Adapters
Page Name Definition Name Navigation Usage
Adapter Table
SCC_EPAY_INT_REG
Set Up SACR, and then System Administration, and then Utilities, and then Adapter Registry, and then Adapter Table, and then Adapter Table
Set up adapters.
Setting Up Adapters
Access the Adapter Table page (Set Up SACR, and then System Administration, and then Utilities, and then Adapter Registry, and then Adapter Table, and then Adapter Table).
This example illustrates the fields and controls on the Adapter Table page. You can find definitions for the fields and controls later on this page.
Adapter Table page
The Adapter ID field identifies the adapter.
Parameters
Field or Control Description
Root Package ID
Select a root Application Class package.
Path
Select a non-root Application Class package.
Application Class ID
Select the Application Class of the adapter.
