Setting Security for Graduation Review
To set up graduation review security, use the Graduation Status Security (SSR_SCRTY_GRADSTAT) component.
This section discusses how to set graduation status security.
Page Used to Set Security for Graduation Review
| Page Name | Definition Name | Navigation | Usage |
Graduation Status Security |
SSR_SCRTY_GRADSTAT |
Identify, by institution, the Graduation Status the user has access to use during graduation tracking. |
Setting Graduation Status Security
Access the Graduation Status Security page ().
This example illustrates the fields and controls on the Graduation Status Security page. You can find definitions for the fields and controls later on this page.
| Field or Control | Description |
Graduation Review Status |
Select the value or values that the UserID can use on the Graduation Tracking page. |
All Access |
Click this button to change the Graduation Review Status to ALL and grant the user access to every status available. |
