1.9.2 Running Conversion Programs Using PeopleSoft Application Engine
Run the following scripts to initially synchronize PeopleSoft SAIP extension tables with their corresponding PeopleSoft Campus Solutions tables.
To run PeopleSoft Application Engine, run psae.exe in the directory PS_HOME\bin\client\winx86.
You can also run these conversion programs by logging into PeopleSoft in the browser and selecting PeopleTools, Application Engine, Request AE.
Application Engine Program Description
SAE_CMBN_EXT
Populates the SAE_CMBN_EXT table based on the SCTN_CMBND table.
SAE_CSEC_EXT
Populates the SAE_CLASS_EXT table based on the CLASS_TBL table.
SAE_CTLG_EXT
Populates the SAE_CRSCTLG_EXT tables based on the CRSE_CATAGLOG table.
SAE_MBRS_EXT
Populates the SAE_INSTR_EXT table based on the CLASS_INSTR table.
SAE_OFFR_EXT
Populates the SAE_CRSOFFER_EXT table based on the CRSE_OFFER table.
SAE_TERM_EXT
Populates the SAE_TERM_EXT table based on the TERM_TBL table.
SAE_SESS_EXT
Populates the SAE_SESSION_EXT table based on the SESSION_TBL table.
See PeopleSoft PeopleTools: Integration Broker for your database platform and for your current PeopleTools release.
